Introduzione
If you need to replace the camera this guide will provide step-by-step instructions on how to disassemble and replace your camera.
Cosa ti serve
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Conclusione
