Salta al contenuto principale
Fujitsu Lifebook Stylistic Q584 Back Case Replacement
Cosa ti serve
  1. Fujitsu Lifebook Stylistic Q584 Back Case Replacement, Back Case: passo 1, immagine 1 di 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Back Case Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Back Case Replacement: passo 3, immagine 1 di 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 832
