Salta al contenuto principale
Fujitsu Lifebook S6120 Screen Replacement
Cosa ti serve
  1. Fujitsu Lifebook S6120 Screen Replacement, Battery: passo 1, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement, Battery: passo 1, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement, Battery: passo 1, immagine 3 di 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: passo 2, immagine 1 di 2 Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: passo 2, immagine 2 di 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Screen Replacement: passo 3, immagine 1 di 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Screen Replacement: passo 4, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 4, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Screen Replacement: passo 5, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 5, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 5, immagine 3 di 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Screen Replacement, Keyboard: passo 6, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement, Keyboard: passo 6, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement, Keyboard: passo 6, immagine 3 di 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Screen Replacement: passo 7, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 7, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 7, immagine 3 di 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: passo 8, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: passo 8, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: passo 8, immagine 3 di 3
    • Push the secure clips outward.
    • The Adapter should pop up.
  9. Fujitsu Lifebook S6120 Screen Replacement: passo 9, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 9, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 9, immagine 3 di 3
    Compra
    • Use tweezers to remove the wires from the Adapter.
  10. Fujitsu Lifebook S6120 Screen Replacement: passo 10, immagine 1 di 2 Fujitsu Lifebook S6120 Screen Replacement: passo 10, immagine 2 di 2
    • Take out the Adapter and carefully pull the wires out from the metal casing.
  11. Fujitsu Lifebook S6120 Screen Replacement, Screen: passo 11, immagine 1 di 2 Fujitsu Lifebook S6120 Screen Replacement, Screen: passo 11, immagine 2 di 2
    • Remove the 4mm screws from the laptop with a Philips head #0
    • Remove the 4.5mm screws on the back of the laptop with a Philips #0
  12. Fujitsu Lifebook S6120 Screen Replacement: passo 12, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 12, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 12, immagine 3 di 3
    • Use a plastic opening tool to lift up both sides of the white tab.
  13. Fujitsu Lifebook S6120 Screen Replacement: passo 13, immagine 1 di 2 Fujitsu Lifebook S6120 Screen Replacement: passo 13, immagine 2 di 2
    Compra
    • Use tweezers to grab onto the lever to remove the chip from the motherboard.
  14. Fujitsu Lifebook S6120 Screen Replacement: passo 14, immagine 1 di 1
    • Lift the screen up vertically
  15. Fujitsu Lifebook S6120 Screen Replacement: passo 15, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 15, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 15, immagine 3 di 3
    • Remove rubber tabs with hands
    • Use a Philips head #0 to remove the 3mm screws
  16. Fujitsu Lifebook S6120 Screen Replacement: passo 16, immagine 1 di 2 Fujitsu Lifebook S6120 Screen Replacement: passo 16, immagine 2 di 2
    • Use the metal spudger to pry up the edge of the plastic casing up.
    • Remove the plastic frame from the screen.
  17. Fujitsu Lifebook S6120 Screen Replacement: passo 17, immagine 1 di 1
    • Remove the 3mm screws with a Philips head #00
  18. Fujitsu Lifebook S6120 Screen Replacement: passo 18, immagine 1 di 1
    • Remove the 2.5mm screws with a Philips head #0 on both sides of the laptop
  19. Fujitsu Lifebook S6120 Screen Replacement: passo 19, immagine 1 di 2 Fujitsu Lifebook S6120 Screen Replacement: passo 19, immagine 2 di 2
    • Lift the screen from the frame
  20. Fujitsu Lifebook S6120 Screen Replacement: passo 20, immagine 1 di 2 Fujitsu Lifebook S6120 Screen Replacement: passo 20, immagine 2 di 2
    • Remove the ribbon from the back of the screen
  21. Fujitsu Lifebook S6120 Screen Replacement: passo 21, immagine 1 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 21, immagine 2 di 3 Fujitsu Lifebook S6120 Screen Replacement: passo 21, immagine 3 di 3
    • Use a pair of tweezers remove the white connector
Conclusione
Jessi Gallant
Membro da: 03/19/18
899 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 944
