Salta al contenuto principale
Introduzione
If your Lifebook won't connect to a wireless network this guide will show you how to replace a wireless adapter so your Lifebook will get a signal.
Parti
Nessuna parte specificata.
  1. To prevent injury, make sure the laptop is unplugged and turned off before removing the battery. Push the two tabs in towards the laptop. Lift the battery up and out from the frame of the laptop.
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer. Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Lift the hinge cover.
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Use the tweezers to disconnect the ribbon cable from the motherboard. Use the tweezers to disconnect the ribbon cable from the motherboard. Use the tweezers to disconnect the ribbon cable from the motherboard.
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Kits di riparazione iPhone X
    Garanzia finita? Non preoccuparti, abbiamo la soluzione.
    Acquista ora
    Acquista ora
  6. With the tweezers detach hinge cover cables from the motherboard. Remove hinge cover. Remove hinge cover.
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  7. Lift keyboard enough to show the ribbon cable. The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage. The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  8. Use a plastic opening tool to release the ribbon cable from the motherboard. Use a plastic opening tool to release the ribbon cable from the motherboard. Use a plastic opening tool to release the ribbon cable from the motherboard.
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  9. Push the secure clips outward. The Adapter should pop up. The Adapter should pop up.
    • Push the secure clips outward.
    • The Adapter should pop up.
  10. Use tweezers to remove the wires from the Adapter. Use tweezers to remove the wires from the Adapter. Use tweezers to remove the wires from the Adapter.
    • Use tweezers to remove the wires from the Adapter.
  11. Take out the Adapter and carefully pull the wires out from the metal casing. Take out the Adapter and carefully pull the wires out from the metal casing.
    • Take out the Adapter and carefully pull the wires out from the metal casing.
Conclusione
Jaimie Nakamura
Membro da: 20/03/2018
205 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 51
