Salta al contenuto principale
Fujitsu Lifebook S6120 Motherboard Replacement
Cosa ti serve
  1. Fujitsu Lifebook S6120 Motherboard Replacement, Battery: passo 1, immagine 1 di 3 Fujitsu Lifebook S6120 Motherboard Replacement, Battery: passo 1, immagine 2 di 3 Fujitsu Lifebook S6120 Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Motherboard Replacement, Hinge Cover: passo 2, immagine 1 di 2 Fujitsu Lifebook S6120 Motherboard Replacement, Hinge Cover: passo 2, immagine 2 di 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Motherboard Replacement: passo 3, immagine 1 di 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Motherboard Replacement: passo 4, immagine 1 di 3 Fujitsu Lifebook S6120 Motherboard Replacement: passo 4, immagine 2 di 3 Fujitsu Lifebook S6120 Motherboard Replacement: passo 4, immagine 3 di 3
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Motherboard Replacement: passo 5, immagine 1 di 3 Fujitsu Lifebook S6120 Motherboard Replacement: passo 5, immagine 2 di 3 Fujitsu Lifebook S6120 Motherboard Replacement: passo 5, immagine 3 di 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: passo 6, immagine 1 di 3 Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: passo 6, immagine 2 di 3 Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: passo 6, immagine 3 di 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Motherboard Replacement: passo 7, immagine 1 di 3 Fujitsu Lifebook S6120 Motherboard Replacement: passo 7, immagine 2 di 3 Fujitsu Lifebook S6120 Motherboard Replacement: passo 7, immagine 3 di 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Motherboard Replacement, Motherboard: passo 8, immagine 1 di 2 Fujitsu Lifebook S6120 Motherboard Replacement, Motherboard: passo 8, immagine 2 di 2
    • Use a Philips head #0 to remove the 5mm screws.
    • Use a Philips head #00 to remove the 4mm screws.
  9. Fujitsu Lifebook S6120 Motherboard Replacement: passo 9, immagine 1 di 1
    • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
  10. Fujitsu Lifebook S6120 Motherboard Replacement: passo 10, immagine 1 di 2 Fujitsu Lifebook S6120 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the ribbon from the motherboard with a pair of tweezers.
  11. Fujitsu Lifebook S6120 Motherboard Replacement: passo 11, immagine 1 di 3 Fujitsu Lifebook S6120 Motherboard Replacement: passo 11, immagine 2 di 3 Fujitsu Lifebook S6120 Motherboard Replacement: passo 11, immagine 3 di 3
    • Use a 5mm nut driver to unscrew the nuts.
  12. Fujitsu Lifebook S6120 Motherboard Replacement: passo 12, immagine 1 di 2 Fujitsu Lifebook S6120 Motherboard Replacement: passo 12, immagine 2 di 2
    • Pull the ribbon tab up and off the motherboard.
  13. Fujitsu Lifebook S6120 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the metal plate covering the motherboard.
  14. Fujitsu Lifebook S6120 Motherboard Replacement: passo 14, immagine 1 di 2 Fujitsu Lifebook S6120 Motherboard Replacement: passo 14, immagine 2 di 2
    • Remove the 3.5mm screws with a Philips head #0.
    • Remove the metal bracket and other pieces that rely on it for structure.
  15. Fujitsu Lifebook S6120 Motherboard Replacement: passo 15, immagine 1 di 2 Fujitsu Lifebook S6120 Motherboard Replacement: passo 15, immagine 2 di 2
    • Pinch your fingers around the base of the connector and pull it out.
  16. Fujitsu Lifebook S6120 Motherboard Replacement: passo 16, immagine 1 di 2 Fujitsu Lifebook S6120 Motherboard Replacement: passo 16, immagine 2 di 2
    • Lift the motherboard off the plastic base.
Conclusione
Jessi Gallant
Membro da: 03/19/18
899 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 998
