Salta al contenuto principale
Fujitsu Lifebook S6120 Keyboard Replacement
Cosa ti serve
  1. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: passo 2, immagine 1 di 2 Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: passo 2, immagine 2 di 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Keyboard Replacement: passo 3, immagine 1 di 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Keyboard Replacement: passo 4, immagine 1 di 3 Fujitsu Lifebook S6120 Keyboard Replacement: passo 4, immagine 2 di 3 Fujitsu Lifebook S6120 Keyboard Replacement: passo 4, immagine 3 di 3
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Keyboard Replacement: passo 5, immagine 1 di 3 Fujitsu Lifebook S6120 Keyboard Replacement: passo 5, immagine 2 di 3 Fujitsu Lifebook S6120 Keyboard Replacement: passo 5, immagine 3 di 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: passo 6, immagine 1 di 3 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: passo 6, immagine 2 di 3 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: passo 6, immagine 3 di 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Keyboard Replacement: passo 7, immagine 1 di 3 Fujitsu Lifebook S6120 Keyboard Replacement: passo 7, immagine 2 di 3 Fujitsu Lifebook S6120 Keyboard Replacement: passo 7, immagine 3 di 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
Conclusione
Jessi Gallant
Membro da: 03/19/18
899 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,071
