Salta al contenuto principale
Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement
Cosa ti serve
  1. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 2, immagine 1 di 1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: passo 3, immagine 1 di 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: passo 3, immagine 2 di 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: passo 3, immagine 3 di 3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 4, immagine 1 di 1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 5, immagine 1 di 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 5, immagine 2 di 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 5, immagine 3 di 3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 6, immagine 1 di 2 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 6, immagine 2 di 2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 7, immagine 1 di 2 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 7, immagine 2 di 2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: passo 8, immagine 1 di 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: passo 8, immagine 2 di 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: passo 8, immagine 3 di 3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 9, immagine 1 di 2 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 9, immagine 2 di 2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 10, immagine 1 di 2 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 10, immagine 2 di 2
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Metal Motherboard Cover: passo 11, immagine 1 di 1
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 12, immagine 1 di 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 12, immagine 2 di 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 12, immagine 3 di 3
    • Lift the cover with fingers and remove.
Conclusione
Neil Daniels
Membro da: 01/17/11
1.411 Reputazione
11 Guide realizzate
Cal Poly, Team 5-18, Amido Winter 2011 Membro di Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,626
