Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
You can install a new hard drive in your computer.
  1. Locate the two clips on the bottom of the computer that support the battery.
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Using your fingers,  push the clips inward and then upward.
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Remove the two screws securing the hard drive access cover.
    • Remove the two screws securing the hard drive access cover.
    • Screws not shown in picture.
  4. Remove hard drive access cover. Remove hard drive access cover.
    • Remove hard drive access cover.
  5. Grasp hard drive sleeve tab and pull out. Grasp hard drive sleeve tab and pull out.
    • Grasp hard drive sleeve tab and pull out.
  6. Remove hard drive from plastic sleeve. Remove hard drive from plastic sleeve. Remove hard drive from plastic sleeve.
    • Remove hard drive from plastic sleeve.
Conclusione
Altre 3 persone hanno completato questa guida.
Neil Daniels
Membro da: 17/01/2011
1.369 Reputazione
11 Guide realizzate
Cal Poly, Team 5-18, Amido Winter 2011 Membro di Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Membri
13 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 90
Tutti i Tempi: 7,433
