Salta al contenuto principale
Fujitsu LIFEBOOK P7010D Hard Drive Replacement
Cosa ti serve
  1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop upside down on a table.
  2. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 2, immagine 1 di 1
    • Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Using your fingers, press both tabs down at once until they are fully depressed.
  3. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 3, immagine 1 di 1
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: passo 4, immagine 1 di 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: passo 4, immagine 2 di 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: passo 4, immagine 3 di 3
    • Push the tab down as far as possible using your finger or plastic opening tool to unlock the disc drive.
    • While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
  5. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: passo 5, immagine 2 di 2
    • On the bottom of the laptop, find the bottom-plate screw holes. They are located near the disc drive. Parallel to them is a 2.4mm screw.
    • After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew.
  6. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 6, immagine 1 di 2 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Flip the laptop over and open it facing you.
    • Use a spudger to lift the bottom black cover on both sides.
    • The cover is connected to an aluminum strip, so be careful lifting it.
    • For the proceeding steps, put on an anti-static wrist strap and clip it to something metal. Ensure that it's clipped to a grounded metal in order to protect the delicate circuitry inside the computer.
  7. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 7, immagine 1 di 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 7, immagine 2 di 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 7, immagine 3 di 3
    • Once the black cover is lifted, flip it and set it on the keyboard.
    • Locate the hardware disc on the right side and gently lift it out. Place it on the side of the laptop.
    • The hard drive is connected with a strip, so be careful when lifting it out.
  8. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 8, immagine 1 di 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 8, immagine 2 di 3 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: passo 8, immagine 3 di 3
    • Flip the hard drive on its side.
    • The pins connected to the hard drive are extremely fragile. Take care in handling the next few steps.
    • Hold the hard drive and use a spudger, preferably a wider one, to remove the black pin holder on the side where it touches the hard drive.
    • Gently wiggle the black pin holder back and forth, on each side, until the holder comes off.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 10-31, Amido Winter 2012 Membro di Cal Poly, Team 10-31, Amido Winter 2012
CPSU-AMIDO-W12S10G31
5 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 28
Tutti i Tempi: 5,340
