Salta al contenuto principale
Fujifilm X30 Lens Replacement
Cosa ti serve
  1. Fujifilm X30 Lens Replacement, Battery: passo 1, immagine 1 di 2 Fujifilm X30 Lens Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the camera upside down.
    • Place your thumb on the switch, and slide it towards the center of the camera.
    • The compartment will pop open.
  2. Fujifilm X30 Lens Replacement: passo 2, immagine 1 di 1
    • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
  3. Fujifilm X30 Lens Replacement: passo 3, immagine 1 di 1
    • Pull the battery out.
  4. Fujifilm X30 Lens Replacement, Lens: passo 4, immagine 1 di 3 Fujifilm X30 Lens Replacement, Lens: passo 4, immagine 2 di 3 Fujifilm X30 Lens Replacement, Lens: passo 4, immagine 3 di 3
    • Begin by removing the outside screws using a Phillips #000 Screwdriver:
    • Remove the three 3.6 mm silver screws located on the bottom of the camera.
    • Remove all four of the 4.7 mm screws from the sides of the camera.
  5. Fujifilm X30 Lens Replacement: passo 5, immagine 1 di 2 Fujifilm X30 Lens Replacement: passo 5, immagine 2 di 2
    • Remove all screws listed below using a Phillips #000 Screwdriver:
    • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
    • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
  6. Fujifilm X30 Lens Replacement: passo 6, immagine 1 di 1
    • Carefully remove the bottom piece of the camera.
  7. Fujifilm X30 Lens Replacement: passo 7, immagine 1 di 1
    • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
    • Gently pull off the back of the camera from the left side so that it is partially open.
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
    • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
  8. Fujifilm X30 Lens Replacement: passo 8, immagine 1 di 3 Fujifilm X30 Lens Replacement: passo 8, immagine 2 di 3 Fujifilm X30 Lens Replacement: passo 8, immagine 3 di 3
    • For all five indicated orange strips:
    • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
  9. Fujifilm X30 Lens Replacement: passo 9, immagine 1 di 1
    • For the final orange strip located behind the top strip:
  10. Fujifilm X30 Lens Replacement: passo 10, immagine 1 di 3 Fujifilm X30 Lens Replacement: passo 10, immagine 2 di 3 Fujifilm X30 Lens Replacement: passo 10, immagine 3 di 3
    • Remove the two 3.4 mm screws at the bottom of the silver plate.
    • Peel back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
    • Peel back the copper plate.
  11. Fujifilm X30 Lens Replacement: passo 11, immagine 1 di 1
    • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 Screwdriver.
    • Lift the motherboard so it is out of your way to remove the lens.
    • You do not need to desolder the motherboard to reach the lens.
  12. Fujifilm X30 Lens Replacement: passo 12, immagine 1 di 1
    • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 Screwdriver.
  13. Fujifilm X30 Lens Replacement: passo 13, immagine 1 di 2 Fujifilm X30 Lens Replacement: passo 13, immagine 2 di 2
    • Pull the lens down so it can clear the silver tab.
    • Then push the lens with your index fingers from the front of the camera until it is removed.
Conclusione
Altre 4 persone hanno completato questa guida.
Haley Moss
Membro da: 01/11/16
366 Reputazione
1 Guida realizzata
Cal Poly, Team 70-3, Forte Winter 2016 Membro di Cal Poly, Team 70-3, Forte Winter 2016
CPSU-FORTE-W16S70G3
5 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 5,566
