Salta al contenuto principale
Fujifilm X-M1 Back Case Replacement
Cosa ti serve
  1. Fujifilm X-M1 Back Case Replacement, Battery: passo 1, immagine 1 di 2 Fujifilm X-M1 Back Case Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the camera upside down to locate the battery compartment.
    • Slide the button up to open the compartment.
    • Slide the orange button up to release the battery.
    • The battery is not shown in these photos.
  2. Fujifilm X-M1 Back Case Replacement, Back Case: passo 2, immagine 1 di 1
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  3. Fujifilm X-M1 Back Case Replacement: passo 3, immagine 1 di 1
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  4. Fujifilm X-M1 Back Case Replacement: passo 4, immagine 1 di 1
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  5. Fujifilm X-M1 Back Case Replacement: passo 5, immagine 1 di 2 Fujifilm X-M1 Back Case Replacement: passo 5, immagine 2 di 2
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  6. Fujifilm X-M1 Back Case Replacement: passo 6, immagine 1 di 3 Fujifilm X-M1 Back Case Replacement: passo 6, immagine 2 di 3 Fujifilm X-M1 Back Case Replacement: passo 6, immagine 3 di 3
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  7. Fujifilm X-M1 Back Case Replacement: passo 7, immagine 1 di 1
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  8. Fujifilm X-M1 Back Case Replacement: passo 8, immagine 1 di 2 Fujifilm X-M1 Back Case Replacement: passo 8, immagine 2 di 2
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  9. Fujifilm X-M1 Back Case Replacement: passo 9, immagine 1 di 3 Fujifilm X-M1 Back Case Replacement: passo 9, immagine 2 di 3 Fujifilm X-M1 Back Case Replacement: passo 9, immagine 3 di 3
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  10. Fujifilm X-M1 Back Case Replacement: passo 10, immagine 1 di 1
    • Slide the frame around the LCD to remove it from the camera.
  11. Fujifilm X-M1 Back Case Replacement: passo 11, immagine 1 di 1
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  12. Fujifilm X-M1 Back Case Replacement: passo 12, immagine 1 di 2 Fujifilm X-M1 Back Case Replacement: passo 12, immagine 2 di 2
    • Use tweezers to unhook the speaker near the left handgrip.
  13. Fujifilm X-M1 Back Case Replacement: passo 13, immagine 1 di 2 Fujifilm X-M1 Back Case Replacement: passo 13, immagine 2 di 2
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  14. Fujifilm X-M1 Back Case Replacement: passo 14, immagine 1 di 3 Fujifilm X-M1 Back Case Replacement: passo 14, immagine 2 di 3 Fujifilm X-M1 Back Case Replacement: passo 14, immagine 3 di 3
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
    • Remove the back case.
Conclusione
Altre 2 persone hanno completato questa guida.
Kelsea Weber
Membro da: 11/12/15
19.864 Reputazione
32 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.767 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,433
