Introduzione
Before attempting repairs, please take note of certain risks of receiving shock from the camera's flash capacitor. Also make sure to ground yourself before operating on or near the camera's motherboard or you might discharge static to crucial components.
Cosa ti serve
Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera.
Once all screws are removed, gently pry open the front casing carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
Altre 8 persone hanno completato questa guida.
13 Commenti
the lens covers on my lens broke (the small black pieces that cover the lenses) and i am unable to put back on, will this affect my camera and pictures because of the ex poser?
When I dropped my instax mini 8, none of the lense pieces broke, they just fell apart, I just need to puzzle them back together. Can you make a tutorial to put the yellow and black parts in the lense back together?
My daughter dropped her camera and the round, hard plastic part that goes over the lens fell out along with a black piece that has four prongs. There is also a spring attached at a section that would look like 4-5 o'clock if looking at the camera head on. I am not sure where the other end of spring attaches to. Please help
I too am having the same problem as the people in the posts above. Is there a solution somewhere? Thanks
I followed this tutorial but when I initally took the case apart a small rectangular piece fell out and I'm not sure where it should go. The piece has a hole which is set to one side, and a slight groove and arch. I can't see the piece on any of the tutorials. Can anyone help? Thanks
Me too! Like the exact same piece fell out and when I put it back together without the piece my lens wouldn't poke all the way out without me pulling it
Could it be one of the tension bars of the film transport?
elime -
At the bottom of the camera to the left side where the wires are. The hole squeezes in between the case lining up with the screw hole & bulge in the case.
Bob -
something is covering my lens, when i take pictures it came out black.
Il y a une vis caché sous la pièce enjoliveur (6cmx 9mm blanche) de sortie des photos
Gaby
Malosse - Replica
Translation: There is a screw hidden under the trim piece (6cmx 9mm white) for outputting the photos.
Alexander Honkoski - Replica
