Salta al contenuto principale
Fujifilm Instax Mini 8 Flash Unit Replacement
Cosa ti serve
  1. Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: passo 1, immagine 1 di 2 Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: passo 1, immagine 2 di 2
    • You start off with the camera.
  2. Fujifilm Instax Mini 8 Flash Unit Replacement: passo 2, immagine 1 di 2 Fujifilm Instax Mini 8 Flash Unit Replacement: passo 2, immagine 2 di 2
    • Open up the back and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Flash Unit Replacement: passo 3, immagine 1 di 2 Fujifilm Instax Mini 8 Flash Unit Replacement: passo 3, immagine 2 di 2
    • Remove the two Phillips #00 screws from the bottom of the camera.
    • Remove the two screws on the side of the camera.
    • Additionally, there are two screws in the battery compartment which also need to be removed.
    There is also a screw underneath the cover for the picture eject slot
    Interessierte Salzgurke - Replica
    I had the same problem with my camera which I have had for about 10 years now all the red lights on my camera came on and I could not use my camera to FIX this problem you need to turn the camera on and replace the batteries with new batteries and this will reset your camera I did this last night and my camera is as good as new now
    Serena - Replica
  4. Fujifilm Instax Mini 8 Flash Unit Replacement: passo 4, immagine 1 di 3 Fujifilm Instax Mini 8 Flash Unit Replacement: passo 4, immagine 2 di 3 Fujifilm Instax Mini 8 Flash Unit Replacement: passo 4, immagine 3 di 3
    • Once all screws are removed, gently pry open the front casing with your hands or a prying tool.
    • There will be a spring that attaches the front casing and the main circuit board, so take care as to not break the spring.
  5. Fujifilm Instax Mini 8 Flash Unit Replacement: passo 5, immagine 1 di 1
    • You should now be able to see the flash unit. Take care to not touch the large black capacitor on the top. It will still have a charge and will hurt.
  6. Fujifilm Instax Mini 8 Flash Unit Replacement: passo 6, immagine 1 di 2 Fujifilm Instax Mini 8 Flash Unit Replacement: passo 6, immagine 2 di 2
    • Unscrew the two screws attaching the flash to the main circuit board. The flash unit will detach away from the motherboard, now leaving just the connecting wires to remove next.
  7. Fujifilm Instax Mini 8 Flash Unit Replacement: passo 7, immagine 1 di 3 Fujifilm Instax Mini 8 Flash Unit Replacement: passo 7, immagine 2 di 3 Fujifilm Instax Mini 8 Flash Unit Replacement: passo 7, immagine 3 di 3
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
    Where can i get a spare flash unit from?
    Jannis Jacob - Replica
Conclusione
Altre 4 persone hanno completato questa guida.
Boyang Wu
Membro da: 10/02/12
955 Reputazione
5 Guide realizzate
USF Tampa, Team 4-1, Meier Fall 2015 Membro di USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Membri
24 Guide realizzate
10 Commenti
Where can I purchase the flash unit?
Casey Sanders - Replica
Hi, did you ever find out where to replace the flash light unit?
Rachel Street -
Why is all the camera lights flashing red and doesn't work?
medgabby - Replica
Will the camera work without any flash, or are the connections required for the whole thing to function ?
Hyaku Gen - Replica
Where can I find the flash unit to purchase??
Maria - Replica
Hello. Can the motherboard of the camera be replaced?
Amal Amjad - Replica
Where can I buy a flash unit for a Fuji instax mini 70?
Rosemary Rendon - Replica
i also need to find out where to buy a flash unit for my fuji instax mini 70 .been try to do web searches but it seems to be so dam hard to find where to buy one
Raymond Ross - Replica
I have a Instax 7s… I want to install a switch in the camera in order to mod it to have a “NO FLASH” option… Where should I put the switch? I was thinking in dividing one of the capacitor areas or the red wire of the flash unit. Any advice?
I also want to do this for the ejecting motor in order to do double expositions (Yep. I’ll be really modding this camera hahaha)
Any advices?
Diulio R. Silva - Replica
Still the same problem: WHERE TO BUY THAT STUPID FLASH TUBE???
Guy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 64
Ultimi 30 Giorni: 252
Tutti i Tempi: 32,491
