Salta al contenuto principale
Fujifilm Instax Mini 8 Capacitor Replacement
Cosa ti serve
  1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: passo 1, immagine 1 di 3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: passo 1, immagine 2 di 3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: passo 1, immagine 3 di 3
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Capacitor Replacement: passo 2, immagine 1 di 2 Fujifilm Instax Mini 8 Capacitor Replacement: passo 2, immagine 2 di 2
    • Open the rear compartment and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Capacitor Replacement: passo 3, immagine 1 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 3, immagine 2 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 3, immagine 3 di 3
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Capacitor Replacement: passo 4, immagine 1 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 4, immagine 2 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 4, immagine 3 di 3
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  5. Fujifilm Instax Mini 8 Capacitor Replacement: passo 5, immagine 1 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 5, immagine 2 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 5, immagine 3 di 3
    • Locate the photo-flash capacitor, then find all the connecting wires to the motherboard and battery compartment. Take notes to which exact wires they are to limit mistakes.
  6. Fujifilm Instax Mini 8 Capacitor Replacement: passo 6, immagine 1 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 6, immagine 2 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 6, immagine 3 di 3
    • Carefully pry out the capacitor with a spudger or plastic opening tools.
  7. Fujifilm Instax Mini 8 Capacitor Replacement: passo 7, immagine 1 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 7, immagine 2 di 3 Fujifilm Instax Mini 8 Capacitor Replacement: passo 7, immagine 3 di 3
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
Conclusione
Altre 4 persone hanno completato questa guida.
Boyang Wu
Membro da: 10/02/12
955 Reputazione
5 Guide realizzate
USF Tampa, Team 4-1, Meier Fall 2015 Membro di USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Membri
24 Guide realizzate
2 Commenti
Hi There! I need a new capacitor for my daughter's Fuji Instax Mini 9. Do you supply? I am in South Africa.
Kuschi - Replica
Hi, any recommendations on where can find a shop in Kl Malaysia to fix my instax mini 8? Thanks in advance !
Miss.G - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 202
Tutti i Tempi: 24,632
