Salta al contenuto principale
Fujifilm Finepix S1800 Battery Replacement
Cosa ti serve
  1. Fujifilm Finepix S1800 Battery Replacement, Battery: passo 1, immagine 1 di 2 Fujifilm Finepix S1800 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the camera over and find the switch to open up the battery storage area.
    • Push and hold the switch towards the lines. Then pull away from the camera to open up the battery storage area.
  2. Fujifilm Finepix S1800 Battery Replacement: passo 2, immagine 1 di 2 Fujifilm Finepix S1800 Battery Replacement: passo 2, immagine 2 di 2
    • Take out the four existing batteries and replace them with four new AA batteries and close the cover.
    • Make sure when putting in the new batteries that the ends alternate from positive, negative, positive again, and then negative again.
Conclusione
USF Tampa, Team 8-6, Eyestone Spring 2017 Membro di USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,590
