Salta al contenuto principale
Fujifilm Finepix S1800 Back Cover Assembly Replacement
Cosa ti serve
  1. Fujifilm Finepix S1800 Back Cover Assembly Replacement, Back Cover Assembly: passo 1, immagine 1 di 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Back Cover Assembly Replacement: passo 2, immagine 1 di 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Back Cover Assembly Replacement: passo 3, immagine 1 di 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Back Cover Assembly Replacement: passo 4, immagine 1 di 2 Fujifilm Finepix S1800 Back Cover Assembly Replacement: passo 4, immagine 2 di 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
Conclusione
USF Tampa, Team 8-6, Eyestone Spring 2017 Membro di USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 378
