Salta al contenuto principale
Fujifilm Finepix S1000fd Rear Cover Casing Replacement
Cosa ti serve
  1. Fujifilm Finepix S1000fd Rear Cover Casing Replacement, Rear Cover Casing: passo 1, immagine 1 di 2 Fujifilm Finepix S1000fd Rear Cover Casing Replacement, Rear Cover Casing: passo 1, immagine 2 di 2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: passo 2, immagine 1 di 2 Fujifilm Finepix S1000fd Rear Cover Casing Replacement: passo 2, immagine 2 di 2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: passo 3, immagine 1 di 1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
Conclusione
Lizzie Eller
Membro da: 01/25/17
422 Reputazione
4 Guide realizzate
Cal Poly, Team 8-7, Banghart Winter 2017 Membro di Cal Poly, Team 8-7, Banghart Winter 2017
CPSU-BANGHART-W17S8G7
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 562
