Salta al contenuto principale
Fujifilm Finepix S1000fd Battery Replacement
  1. Fujifilm Finepix S1000fd Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the camera upside down.
  2. Fujifilm Finepix S1000fd Battery Replacement: passo 2, immagine 1 di 1
    • Flick the switch on the right side of the camera, and bring it downwards, while simultaneously lifting up the cover.
    • While the switch is held down, lift up the battery compartment cover.
  3. Fujifilm Finepix S1000fd Battery Replacement: passo 3, immagine 1 di 1
    • Observe that the signs on the battery compartment will show you how to insert the 4 AA batteries.
    • There should be positive battery signs near the bottom slot and the third slot from the bottom.
    • There should be negative battery signs near the top slot and the second slot from the bottom.
Conclusione
Cal Poly, Team 8-7, Banghart Winter 2017 Membro di Cal Poly, Team 8-7, Banghart Winter 2017
CPSU-BANGHART-W17S8G7
4 Membri
10 Guide realizzate
3 Commenti
My S1000 takes 1 battery not five…
francanadaswan - Replica
My Fuji S1000 digital camera takes 1 battery, not five. Where can I get a replacement? Nothing on Amazon.
My s1000fd takes 4 batteries... how would i clean it after the batteries leaked in the battery well? is it salvageable?
Beckmansbabe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,672
