Salta al contenuto principale
Fujifilm Finepix F10 6.3 MP LCD Replacement
Cosa ti serve
  1. Fujifilm Finepix F10 6.3 MP LCD Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 2, immagine 1 di 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 3, immagine 1 di 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 4, immagine 1 di 3 Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 4, immagine 2 di 3 Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 4, immagine 3 di 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP LCD Replacement, LCD: passo 5, immagine 1 di 1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 6, immagine 1 di 1
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 7, immagine 1 di 2 Fujifilm Finepix F10 6.3 MP LCD Replacement: passo 7, immagine 2 di 2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Conclusione
Sarah Looper
Membro da: 03/11/13
100 Reputazione
7 Guide realizzate
Clemson, Team 13-4, Benson Spring 2013 Membro di Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Membri
16 Guide realizzate
3 Commenti
Great Guide! Worked great to replace my screen!
Daniel - Replica
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Johnston Thayer - Replica
Shutter button replacement was great too!
Daniel -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 962
