Introduzione
This guide will explain how to remove the front cover from the camera. This is the cover that surrounds the lens side of the camera. Removing screws from the motherboard will allow the front casing to be removed.
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
  • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
Aggiungi Commento
Remove screws from charger side of camera using the Phillips 00 screwdriver.
  • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
Aggiungi Commento
  • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
Aggiungi Commento
  • Separate the front and back casing using the spudger.
  • Gently pull apart the two casings.
  • Pull the back casing away from the camera.
Aggiungi Commento
  • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
Aggiungi Commento
  • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
Aggiungi Commento
  • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
Aggiungi Commento
Conclusione
Sarah Looper
Membro da: 11/03/2013
76 Reputazione
7 Guide realizzate
Clemson, Team 13-4, Benson Spring 2013 Membro di Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 553
