Salta al contenuto principale
Fujifilm FinePix XP80 Lens Replacement
Cosa ti serve
  1. Fujifilm FinePix XP80 Lens Replacement, Battery: passo 1, immagine 1 di 3 Fujifilm FinePix XP80 Lens Replacement, Battery: passo 1, immagine 2 di 3 Fujifilm FinePix XP80 Lens Replacement, Battery: passo 1, immagine 3 di 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Lens Replacement: passo 2, immagine 1 di 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Lens Replacement, Exterior Case: passo 3, immagine 1 di 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Lens Replacement: passo 4, immagine 1 di 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Lens Replacement: passo 5, immagine 1 di 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Lens Replacement: passo 6, immagine 1 di 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Lens Replacement: passo 7, immagine 1 di 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Lens Replacement: passo 8, immagine 1 di 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Lens Replacement: passo 9, immagine 1 di 2 Fujifilm FinePix XP80 Lens Replacement: passo 9, immagine 2 di 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Lens Replacement, Interior Case: passo 10, immagine 1 di 1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Lens Replacement: passo 11, immagine 1 di 1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Lens Replacement: passo 12, immagine 1 di 1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Lens Replacement: passo 13, immagine 1 di 3 Fujifilm FinePix XP80 Lens Replacement: passo 13, immagine 2 di 3 Fujifilm FinePix XP80 Lens Replacement: passo 13, immagine 3 di 3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Lens Replacement: passo 14, immagine 1 di 1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Lens Replacement, Lens: passo 15, immagine 1 di 1
    • Using a plastic opening tool, remove the entire lens housing.
    • Install the new lens and housing (it is replaced as a single unit).
Conclusione
Amanda Lewis
Membro da: 09/25/16
317 Reputazione
3 Guide realizzate
USF Tampa, Team 1-3, Cagle Fall 2016 Membro di USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,503
