Salta al contenuto principale
Fujifilm FinePix T500 Lens Replacement
Cosa ti serve
  1. Fujifilm FinePix T500 Lens Replacement, LCD Screen: passo 1, immagine 1 di 3 Fujifilm FinePix T500 Lens Replacement, LCD Screen: passo 1, immagine 2 di 3 Fujifilm FinePix T500 Lens Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 Lens Replacement: passo 2, immagine 1 di 3 Fujifilm FinePix T500 Lens Replacement: passo 2, immagine 2 di 3 Fujifilm FinePix T500 Lens Replacement: passo 2, immagine 3 di 3
    • Open the battery compartment and remove the battery.
    • Carefully pry the front half of the casing away from the camera.
    • Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
  3. Fujifilm FinePix T500 Lens Replacement: passo 3, immagine 1 di 2 Fujifilm FinePix T500 Lens Replacement: passo 3, immagine 2 di 2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 Lens Replacement: passo 4, immagine 1 di 3 Fujifilm FinePix T500 Lens Replacement: passo 4, immagine 2 di 3 Fujifilm FinePix T500 Lens Replacement: passo 4, immagine 3 di 3
    • Lift the LCD screen out of the camera.
    • Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
  5. Fujifilm FinePix T500 Lens Replacement, Lens: passo 5, immagine 1 di 1
    • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
  6. Fujifilm FinePix T500 Lens Replacement: passo 6, immagine 1 di 3 Fujifilm FinePix T500 Lens Replacement: passo 6, immagine 2 di 3 Fujifilm FinePix T500 Lens Replacement: passo 6, immagine 3 di 3
    • Pry off the center casing of the camera. Separate the top and side sections individually before fully removing the casing.
  7. Fujifilm FinePix T500 Lens Replacement: passo 7, immagine 1 di 3 Fujifilm FinePix T500 Lens Replacement: passo 7, immagine 2 di 3 Fujifilm FinePix T500 Lens Replacement: passo 7, immagine 3 di 3
    • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
  8. Fujifilm FinePix T500 Lens Replacement: passo 8, immagine 1 di 2 Fujifilm FinePix T500 Lens Replacement: passo 8, immagine 2 di 2
    • Pry the metal plate out using the spudger.
  9. Fujifilm FinePix T500 Lens Replacement: passo 9, immagine 1 di 3 Fujifilm FinePix T500 Lens Replacement: passo 9, immagine 2 di 3 Fujifilm FinePix T500 Lens Replacement: passo 9, immagine 3 di 3
    • Peel back the strip of black tape to reveal a red and black wire.
    • Detach the orange ribbon by gently pulling on it.
    • Detach the golden ribbon by gently lifting it with the spudger.
  10. Fujifilm FinePix T500 Lens Replacement: passo 10, immagine 1 di 2 Fujifilm FinePix T500 Lens Replacement: passo 10, immagine 2 di 2
    • The lens should now be free to simply be pushed out of its socket.
    • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
Conclusione
Brian Lasher
Membro da: 01/16/15
325 Reputazione
3 Guide realizzate
USF Tampa, Team 19-3, Blackwell Winter 2015 Membro di USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,175
