Salta al contenuto principale
Fujifilm FinePix T500 LCD Screen Replacement
Cosa ti serve
  1. Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 LCD Screen Replacement: passo 2, immagine 1 di 3 Fujifilm FinePix T500 LCD Screen Replacement: passo 2, immagine 2 di 3 Fujifilm FinePix T500 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Open the battery compartment and remove the battery.
    • Carefully pry the front half of the casing away from the camera.
    • Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
  3. Fujifilm FinePix T500 LCD Screen Replacement: passo 3, immagine 1 di 2 Fujifilm FinePix T500 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 LCD Screen Replacement: passo 4, immagine 1 di 3 Fujifilm FinePix T500 LCD Screen Replacement: passo 4, immagine 2 di 3 Fujifilm FinePix T500 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Lift the LCD screen out of the camera.
    • Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
Conclusione
USF Tampa, Team 19-3, Blackwell Winter 2015 Membro di USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 856
