Salta al contenuto principale
Fujifilm FinePix S8630 Flash Lid Spring Replacement
Cosa ti serve
  1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Battery Door: passo 1, immagine 1 di 1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 2, immagine 1 di 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 3, immagine 1 di 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 4, immagine 1 di 2 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 4, immagine 2 di 2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 5, immagine 1 di 1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 6, immagine 1 di 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 6, immagine 2 di 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 6, immagine 3 di 3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 7, immagine 1 di 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 7, immagine 2 di 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 7, immagine 3 di 3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: passo 8, immagine 1 di 2 Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: passo 8, immagine 2 di 2
    • Firmly grasp the flash bulb lid and remove the lid from the camera.
  9. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 9, immagine 1 di 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 9, immagine 2 di 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: passo 9, immagine 3 di 3
    • Locate the spring and grasp with the tweezers.
    • Pinch and compress the spring to remove it from the camera housing.
    • Slide the lever that was holding the spring out of the camera housing.
Conclusione
USF Tampa, Team 3-2, Sullivan Spring 2016 Membro di USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 306
