Salta al contenuto principale
Fujifilm FinePix S8630 Button Panel Replacement
Cosa ti serve
  1. Fujifilm FinePix S8630 Button Panel Replacement, Battery Door: passo 1, immagine 1 di 1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Button Panel Replacement: passo 2, immagine 1 di 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Button Panel Replacement: passo 3, immagine 1 di 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Button Panel Replacement: passo 4, immagine 1 di 2 Fujifilm FinePix S8630 Button Panel Replacement: passo 4, immagine 2 di 2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Button Panel Replacement: passo 5, immagine 1 di 1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Button Panel Replacement: passo 6, immagine 1 di 3 Fujifilm FinePix S8630 Button Panel Replacement: passo 6, immagine 2 di 3 Fujifilm FinePix S8630 Button Panel Replacement: passo 6, immagine 3 di 3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Button Panel Replacement: passo 7, immagine 1 di 3 Fujifilm FinePix S8630 Button Panel Replacement: passo 7, immagine 2 di 3 Fujifilm FinePix S8630 Button Panel Replacement: passo 7, immagine 3 di 3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: passo 8, immagine 1 di 3 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: passo 8, immagine 2 di 3 Fujifilm FinePix S8630 Button Panel Replacement, Button Panel: passo 8, immagine 3 di 3
    • Take the back casing and push the button panel out gently. The panel will easily fall out and can easily be replaced.
Conclusione
USF Tampa, Team 3-2, Sullivan Spring 2016 Membro di USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 377
