Introduzione
We will give a step by step instruction on how to replace the battery door of your camera.
Cosa ti serve
Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
Un commento
I have just replaced the battery door.
There is no need to to do Step 7.
At step 6 when prying the front and back open.
You can insert the new battery cover simply by inserting the cover on an angle.
The two lugs will just fit into the cavity.
Close and insert all screws.
Job is finished.
