Salta al contenuto principale
Fujifilm FinePix S8200 Rear Housing Cover Replacement
Cosa ti serve
  1. Fujifilm FinePix S8200 Rear Housing Cover  Replacement, Batteries: passo 1, immagine 1 di 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Rear Housing Cover  Replacement: passo 2, immagine 1 di 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Rear Housing Cover  Replacement: passo 3, immagine 1 di 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. Fujifilm FinePix S8200 Rear Housing Cover  Replacement, Rear Housing Cover: passo 4, immagine 1 di 3 Fujifilm FinePix S8200 Rear Housing Cover  Replacement, Rear Housing Cover: passo 4, immagine 2 di 3 Fujifilm FinePix S8200 Rear Housing Cover  Replacement, Rear Housing Cover: passo 4, immagine 3 di 3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. Fujifilm FinePix S8200 Rear Housing Cover  Replacement: passo 5, immagine 1 di 3 Fujifilm FinePix S8200 Rear Housing Cover  Replacement: passo 5, immagine 2 di 3 Fujifilm FinePix S8200 Rear Housing Cover  Replacement: passo 5, immagine 3 di 3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. Fujifilm FinePix S8200 Rear Housing Cover  Replacement: passo 6, immagine 1 di 1
    • Remove the rear housing cover by carefully pulling it away from the camera.
Conclusione
Marcos
Membro da: 01/20/15
101 Reputazione
1 Guida realizzata
USF Tampa, Team 7-1, Remmell Winter 2015 Membro di USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Membri
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,018
