Introduzione
The rear housing cover protects the back of the camera. If the rear housing cover is cracked or damaged, it should be replaced.
Parti
Nessuna parte richiesta.
Turn the camera upside down so you can access the battery chamber.
  • Turn the camera upside down so you can access the battery chamber.
  • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
Aggiungi Commento
Push the battery chamber latch in the direction of the front of the camera.  Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
Aggiungi Commento
  • With the battery chamber open, remove the old batteries.
  • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
Aggiungi Commento
  • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
Aggiungi Commento
  • Carefully pry away the rear housing cover with the plastic opening tool.
Aggiungi Commento
  • Remove the rear housing cover by carefully pulling it away from the camera.
Aggiungi Commento
Conclusione
Marcos
Membro da: 20/01/2015
101 Reputazione
1 Guida realizzata
USF Tampa, Team 7-1, Remmell Winter 2015 Membro di USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 541
