Salta al contenuto principale
Fujifilm FinePix S8200 Batteries Replacement
  1. Fujifilm FinePix S8200 Batteries Replacement, Batteries: passo 1, immagine 1 di 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Batteries Replacement: passo 2, immagine 1 di 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Batteries Replacement: passo 3, immagine 1 di 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
Conclusione
Insert your new batteries, close the battery chamber, and you're done!
Greg Sweeney
Membro da: 01/14/15
137 Reputazione
1 Guida realizzata
USF Tampa, Team 7-1, Remmell Winter 2015 Membro di USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Membri
9 Guide realizzate
3 Commenti
should there be an indicator led to show the camera is charing ?
tony smith - Replica
should the camera indicate that it is being charged ?
When changing battery the date and time is reset. Is there a backup battery ?
BRIAN STIFF - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,944
