Salta al contenuto principale
Fujifilm FinePix S4800 Battery Replacement
  1. Fujifilm FinePix S4800 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Battery Replacement: passo 2, immagine 1 di 3 Fujifilm FinePix S4800 Battery Replacement: passo 2, immagine 2 di 3 Fujifilm FinePix S4800 Battery Replacement: passo 2, immagine 3 di 3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
Conclusione
USF Tampa, Team S19-G4, Hoffman Spring 2017 Membro di USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 65
Tutti i Tempi: 3,060
