Salta al contenuto principale
Fujifilm FinePix S4200 Lens Replacement
Cosa ti serve
  1. Fujifilm FinePix S4200 Lens Replacement, Lens: passo 1, immagine 1 di 1
    • Turn off the camera by pushing the ON/OFF switch as shown.
  2. Fujifilm FinePix S4200 Lens Replacement: passo 2, immagine 1 di 3 Fujifilm FinePix S4200 Lens Replacement: passo 2, immagine 2 di 3 Fujifilm FinePix S4200 Lens Replacement: passo 2, immagine 3 di 3
    • Using a Phillips #000 screwdriver, remove all of the 4mm screws from the left, right, and bottom of the camera.
  3. Fujifilm FinePix S4200 Lens Replacement: passo 3, immagine 1 di 1
    • Remove casing part pictured by gently pulling up until casing is fully detached.
  4. Fujifilm FinePix S4200 Lens Replacement: passo 4, immagine 1 di 3 Fujifilm FinePix S4200 Lens Replacement: passo 4, immagine 2 di 3 Fujifilm FinePix S4200 Lens Replacement: passo 4, immagine 3 di 3
    • Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
    • Use the Phillips #000 to avoid stripping the screws.
  5. Fujifilm FinePix S4200 Lens Replacement: passo 5, immagine 1 di 1
    • Remove orange ribbon cable by gently pulling on the cable until it is detached from the clamping device on the motherboard.
    • Remove the top casing by pulling upwards.
  6. Fujifilm FinePix S4200 Lens Replacement: passo 6, immagine 1 di 2 Fujifilm FinePix S4200 Lens Replacement: passo 6, immagine 2 di 2
    • Carefully remove the LCD screen.
    • Gently pull on orange tab until it is free. This orange strip is susceptible to tearing.
  7. Fujifilm FinePix S4200 Lens Replacement: passo 7, immagine 1 di 2 Fujifilm FinePix S4200 Lens Replacement: passo 7, immagine 2 di 2
    • Remove remaining 4mm screw. Detach metal plate by lifting plate upwards.
    • Use the Phillips #000 screwdriver.
  8. Fujifilm FinePix S4200 Lens Replacement: passo 8, immagine 1 di 1
    • Remove remaining orange tabs on motherboard by gently pulling on all tab until they are free.
    • Caution: Orange strips are susceptible to tearing.
  9. Fujifilm FinePix S4200 Lens Replacement: passo 9, immagine 1 di 1
    • Using the Phillips #000 screwdriver, remove the 4mm screws in the corners of the motherboard.
  10. Fujifilm FinePix S4200 Lens Replacement: passo 10, immagine 1 di 1
    • Use a soldering iron to desolder the five connections shown.
    • Caution: After removing the soldered connections, they must be given ample time to cool before moving to the next step.
  11. Fujifilm FinePix S4200 Lens Replacement: passo 11, immagine 1 di 1
    • Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
  12. Fujifilm FinePix S4200 Lens Replacement: passo 12, immagine 1 di 2 Fujifilm FinePix S4200 Lens Replacement: passo 12, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the 4mm screws around the metal plate.
    • Using a Phillips #000 screwdriver, remove the 10mm screws.
  13. Fujifilm FinePix S4200 Lens Replacement: passo 13, immagine 1 di 1
    • Slowly lift up the metal plate and remove it from the camera.
  14. Fujifilm FinePix S4200 Lens Replacement: passo 14, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the 10mm screw.
  15. Fujifilm FinePix S4200 Lens Replacement: passo 15, immagine 1 di 2 Fujifilm FinePix S4200 Lens Replacement: passo 15, immagine 2 di 2
    • Remove the inner lens.
    • Caution: Be careful while removing the lens.
  16. Fujifilm FinePix S4200 Lens Replacement: passo 16, immagine 1 di 1
    • Change the broken inner lens with a new inner lens.
    • Reassemble the camera.
Conclusione
Joshua Greer
Membro da: 10/31/18
253 Reputazione
1 Guida realizzata
IUPUI, Team S1-G5, Harley Fall 2018 Membro di IUPUI, Team S1-G5, Harley Fall 2018
IUPUI-HARLEY-F18S1G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,684
