Salta al contenuto principale
Fujifilm FinePix HS30EXR Discharge Flash Replacement
Cosa ti serve
  1. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Frame: passo 1, immagine 1 di 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 2, immagine 1 di 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 3, immagine 1 di 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 4, immagine 1 di 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 5, immagine 1 di 1
  6. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 6, immagine 1 di 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 7, immagine 1 di 2 Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 7, immagine 2 di 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Motherboard: passo 8, immagine 1 di 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 9, immagine 1 di 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 10, immagine 1 di 1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 11, immagine 1 di 1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 12, immagine 1 di 1
  13. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 13, immagine 1 di 1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 14, immagine 1 di 1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Discharge Flash Replacement: passo 15, immagine 1 di 1
    • Remove the motherboard.
  16. Fujifilm FinePix HS30EXR Discharge Flash Replacement, Discharge Flash: passo 16, immagine 1 di 1
    • Remove the discharge flash by giving it a light tug. It is held in place with glue.
    • Replace the old flash bulb with a new one, and begin the reconstruction of the device.
Conclusione
Haden Calvert
Membro da: 10/22/18
100 Reputazione
1 Guida realizzata
Baylor, Team S1-G2, Williams Fall 2018 Membro di Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 763
