Salta al contenuto principale
Fujifilm FinePix AX665 Lens Housing Replacement
Cosa ti serve
  1. Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: passo 1, immagine 1 di 3 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: passo 1, immagine 2 di 3 Fujifilm FinePix AX665 Lens Housing Replacement, Lens Housing: passo 1, immagine 3 di 3
    • Use a #00 Phillips screwdriver to remove all six screws around the camera that is holding the case.
  2. Fujifilm FinePix AX665 Lens Housing Replacement: passo 2, immagine 1 di 3 Fujifilm FinePix AX665 Lens Housing Replacement: passo 2, immagine 2 di 3 Fujifilm FinePix AX665 Lens Housing Replacement: passo 2, immagine 3 di 3
    • Use a plastic pick to separate each side of the camera case apart.
  3. Fujifilm FinePix AX665 Lens Housing Replacement: passo 3, immagine 1 di 2 Fujifilm FinePix AX665 Lens Housing Replacement: passo 3, immagine 2 di 2
    • Remove the ribbon cable from the side of the logic board.
  4. Fujifilm FinePix AX665 Lens Housing Replacement: passo 4, immagine 1 di 2 Fujifilm FinePix AX665 Lens Housing Replacement: passo 4, immagine 2 di 2
    • Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
  5. Fujifilm FinePix AX665 Lens Housing Replacement: passo 5, immagine 1 di 2 Fujifilm FinePix AX665 Lens Housing Replacement: passo 5, immagine 2 di 2
    • Carefully flip the screen and remove the ribbon cable attaching it to the logic board.
  6. Fujifilm FinePix AX665 Lens Housing Replacement: passo 6, immagine 1 di 1
    • Remove the three screws holding the sensor.
  7. Fujifilm FinePix AX665 Lens Housing Replacement: passo 7, immagine 1 di 1
    • Remove the sensor ribbon cable from the logic board.
  8. Fujifilm FinePix AX665 Lens Housing Replacement: passo 8, immagine 1 di 1
    • Remove the lens housing ribbon cable.
  9. Fujifilm FinePix AX665 Lens Housing Replacement: passo 9, immagine 1 di 1
    • Remove the lens housing by moving the gray clip holding the unit.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 295
