Salta al contenuto principale
Fujifilm FinePix A350 Memory Card Replacement
  1. Fujifilm FinePix A350 Memory Card Replacement, Batteries: passo 1, immagine 1 di 3 Fujifilm FinePix A350 Memory Card Replacement, Batteries: passo 1, immagine 2 di 3 Fujifilm FinePix A350 Memory Card Replacement, Batteries: passo 1, immagine 3 di 3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Memory Card Replacement, Memory Card: passo 2, immagine 1 di 3 Fujifilm FinePix A350 Memory Card Replacement, Memory Card: passo 2, immagine 2 di 3 Fujifilm FinePix A350 Memory Card Replacement, Memory Card: passo 2, immagine 3 di 3
    • Locate the memory card in the long, thin slot above the battery compartment.
    • Using your thumb, push the memory card farther into the camera.
    • The memory card is spring-loaded and will pop out of the camera far enough to be removed by hand.
Conclusione
Jaxon Cramer
Membro da: 03/21/16
1.045 Reputazione
9 Guide realizzate
Clemson, Team 6-4, Benson Spring 2016 Membro di Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
4 Membri
17 Guide realizzate
Un commento
Bonjour monsieur,
Pourquoi je ‘arrive plus à voir les photos je peu les prendre mais pas les voir “erreurs écriture “
Carte sd vierge.
Merci pour votre aide et bonne soirée
oli.ber - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 68
Tutti i Tempi: 1,189
