Salta al contenuto principale
Fujifilm FinePix A350 Flash Unit Replacement
Cosa ti serve
  1. Fujifilm FinePix A350 Flash Unit Replacement, Batteries: passo 1, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Batteries: passo 1, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Batteries: passo 1, immagine 3 di 3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Flash Unit Replacement, Memory Card: passo 2, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Memory Card: passo 2, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Memory Card: passo 2, immagine 3 di 3
    • Locate the memory card in the long, thin slot above the battery compartment.
    • Using your thumb, push the memory card farther into the camera.
    • The memory card is spring-loaded and will pop out of the camera far enough to be removed by hand.
  3. Fujifilm FinePix A350 Flash Unit Replacement, Speaker: passo 3, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Speaker: passo 3, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Speaker: passo 3, immagine 3 di 3
    • Locate the two 5.0 mm screws on the bottom of the camera and remove them using a tri-point screwdriver with a Y0 bit.
    • Locate the two 3.0 mm screws on the side of the camera with the wrist strap and remove them using a tri-point screwdriver with a Y0 bit.
    • Locate the single 5.0 mm screw on the opposite side of the camera and remove it using a tri-point screwdriver with a Y0 bit.
  4. Fujifilm FinePix A350 Flash Unit Replacement: passo 4, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 4, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 4, immagine 3 di 3
    • Ensure that the batteries are removed and the camera is not connected to any external power source. Never touch any part of the interior of the device when powered.
    • Pry the case apart. Note that the case is very tightly sealed and will be difficult to open. Use a plastic opening tool on the crease between the two halves of the case and put two fingers in the battery compartment to create leverage to pull apart. The battery compartment is attached to the half of the case that contains the lens.
    • Once the two halves of the case have begun to come apart, pull the wrist strap away from the front of the camera to remove it.
  5. Fujifilm FinePix A350 Flash Unit Replacement: passo 5, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 5, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 5, immagine 3 di 3
    • Once the wrist strap has been removed, continue to carefully pull the two halves of the case away from each other.
    • Tilt the back half of the case away from the battery compartment. Proceed slowly to avoid damage to the ribbon cable that is connected to the screen.
    • Locate the speaker at the end of the pair of red and black wires holding the halves of the case together. Take care not to pull the wires, else they may detach from the motherboard and damage the camera.
  6. Fujifilm FinePix A350 Flash Unit Replacement: passo 6, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 6, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 6, immagine 3 di 3
    • Slide the speaker pad away from the back half of the case and out of its holster.
    • After the speaker pad has been removed, the two halves of the case will be connected solely by a ribbon cable leading to the screen. The speaker wires will remain attached to the motherboard.
    • To completely remove the speaker, use a soldering iron to desolder the red and black wires connecting the speaker to the motherboard. Note the black wire goes to the terminal closest to the outside of the camera.
    • If you lack experience in soldering, or need a refresher, refer to the iFixit soldering guide.
    • Desoldering the speaker is not a prerequisite for subsequent guides.
  7. Fujifilm FinePix A350 Flash Unit Replacement, LCD Screen: passo 7, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement, LCD Screen: passo 7, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement, LCD Screen: passo 7, immagine 3 di 3
    • Locate the four 3.0 mm screws holding a thin, black plastic film to the back of the LCD screen. Remove them using a Phillips screwdriver with a #0 bit.
    • After the screws have been removed, the black plastic film and LCD screen can be removed by lifting up the end opposite the attached ribbon cable.
  8. Fujifilm FinePix A350 Flash Unit Replacement: passo 8, immagine 1 di 2 Fujifilm FinePix A350 Flash Unit Replacement: passo 8, immagine 2 di 2
    • Locate the wide ribbon cable connecting the screen to the motherboard.
    • Place your thumb at the base of the ribbon cable where it connects to the motherboard. Carefully pull the ribbon cable out of its connector without pulling it up or away from the motherboard.
    • The ribbon cable should detach from the motherboard but remain connected to the screen, which can now be removed from the camera.
  9. Fujifilm FinePix A350 Flash Unit Replacement, Motherboard: passo 9, immagine 1 di 2 Fujifilm FinePix A350 Flash Unit Replacement, Motherboard: passo 9, immagine 2 di 2
    • Locate four black 3.0 mm screws on the motherboard and remove them using a Phillips screwdriver with a #0 bit.
  10. Fujifilm FinePix A350 Flash Unit Replacement: passo 10, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 10, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 10, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate the two orange ribbon cables next to the LCD screen connector. Starting with the smaller cable, use a pair of tweezers to slide the two ends of the black clamp away from the pale plastic connector.
    • Use tweezers to carefully remove the smaller cable from its connector.
  11. Fujifilm FinePix A350 Flash Unit Replacement: passo 11, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 11, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 11, immagine 3 di 3
    • Use tweezers to slide the two ends of the black clamp away from the pale plastic connector of the larger ribbon cable.
    • Use tweezers to carefully remove the larger cable from its connector.
  12. Fujifilm FinePix A350 Flash Unit Replacement: passo 12, immagine 1 di 2 Fujifilm FinePix A350 Flash Unit Replacement: passo 12, immagine 2 di 2
    • Locate a third ribbon cable, near the previous two, but on the underside of the motherboard.
    • Slightly raise the motherboard to access the ribbon cable with a pair of tweezers. Remove the cable from its connector, following the same procedure as above.
    • Once these three ribbon cables have been removed, the motherboard will be connected to the case only by a fourth ribbon cable and a pair of red and black wires in one corner.
  13. Fujifilm FinePix A350 Flash Unit Replacement: passo 13, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 13, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 13, immagine 3 di 3
    • Separate the motherboard from the case by pulling directly upward. Some resistance is normal; the board is loosely held in place by plastic notches and grooves. It will still be connected via a pair of red and black wires and a fourth small ribbon cable.
    • Locate the fourth ribbon cable on the underside of the motherboard where the red and black wires connect to the battery compartment. Unlike the previous ribbon cables, the clamp is white and the connector is black. Use tweezers to loosen the white clamp before disconnecting the ribbon cable.
    • To completely remove the board, use a soldering iron to desolder the red and black wires connecting the motherboard to the battery compartment. Note the black wire goes to the terminal closest to the memory card slot.
    • Desoldering the motherboard is not a prerequisite for subsequent guides.
  14. Fujifilm FinePix A350 Flash Unit Replacement, Lens: passo 14, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Lens: passo 14, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Lens: passo 14, immagine 3 di 3
    Compra
    • Locate the six 4.0 mm screws securing the three metal brackets to the lens assembly. Remove them using a Phillips screwdriver with a #0 bit.
    • Use tweezers to remove the three metal brackets underneath the screws.
  15. Fujifilm FinePix A350 Flash Unit Replacement: passo 15, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 15, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement: passo 15, immagine 3 di 3
    • Grasp the lens assembly and carefully lift it out of the camera.
  16. Fujifilm FinePix A350 Flash Unit Replacement, Flash Unit: passo 16, immagine 1 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Flash Unit: passo 16, immagine 2 di 3 Fujifilm FinePix A350 Flash Unit Replacement, Flash Unit: passo 16, immagine 3 di 3
    • Locate the two 4.0 mm screws that hold the flash unit and remove them using a Phillips #0 screwdriver .
    • Remove the flash unit by grasping the chip (not the attached capacitor) and lifting it up from the case of the camera.
Conclusione
Jaxon Cramer
Membro da: 03/21/16
1.045 Reputazione
9 Guide realizzate
Clemson, Team 6-4, Benson Spring 2016 Membro di Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 189
