Salta al contenuto principale
Fujifilm FinePix A350 Battery Contact Replacement
Cosa ti serve
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: passo 1, immagine 1 di 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: passo 1, immagine 2 di 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: passo 1, immagine 3 di 3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: passo 2, immagine 1 di 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: passo 2, immagine 2 di 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: passo 2, immagine 3 di 3
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
Conclusione
Jaxon Cramer
Membro da: 03/21/16
1.045 Reputazione
9 Guide realizzate
Clemson, Team 6-4, Benson Spring 2016 Membro di Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
4 Membri
17 Guide realizzate
Un commento
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 495
