Cosa ti serve
Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
Four 3.95mm Phillips screws located on the bottom of the camera
Two 3.95mm Phillips screws located on the right side of the camera
One 3.95mm Phillips screw located on the left side of the camera
Wedge the edge of the spudger between the front and back case, near the corner of the flash.
Carefully run the spudger along the right edge of the camera, creating an opening.
Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use the spudger to push in the white tab on the square circuit board attached to the front case.
Use your finger to pull back the black plastic mount on the right side of the circuit board.
While holding back the black plastic mount, use the tweezers to gently lift the ribbon attached to the circuit board.
Un commento
Hello! Great guide, congratulations indeed! Could you tell me where to find the orange ribbons to replace them? Thanks!
