Salta al contenuto principale
Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement
Cosa ti serve
  1. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: passo 1, immagine 1 di 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: passo 1, immagine 2 di 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Back Cover: passo 1, immagine 3 di 3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 2, immagine 1 di 1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 3, immagine 1 di 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 3, immagine 2 di 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 3, immagine 3 di 3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 4, immagine 1 di 2 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 4, immagine 2 di 2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 5, immagine 1 di 1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
  6. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement, Button Circuit Board: passo 6, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the two screws on the bracket holding the right side of the button circuit board.
    • One 3.85mm Phillips #00 screw
    • One 3.4mm Phillips #00 screw
  7. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 7, immagine 1 di 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 7, immagine 2 di 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 7, immagine 3 di 3
    • Use your fingers to remove the metal bracket and brown colored film.
  8. Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 8, immagine 1 di 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 8, immagine 2 di 3 Fujifilm FinePix 4700 Zoom Button Circuit Board Replacement: passo 8, immagine 3 di 3
    • Use the spudger to pry up the clear plastic tab.
    • Pull the button receiver, button circuit board, and swivel button out as a single unit.
    • Jiggle the swivel button out of place if necessary.
Conclusione
Sarah Daliva
Membro da: 04/04/12
14 Reputazione
2 Guide realizzate
Cal Poly, Team 14-8, Forte Spring 2012 Membro di Cal Poly, Team 14-8, Forte Spring 2012
CPSU-FORTE-S12S14G8
5 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,301
