Salta al contenuto principale
Fujifilm Fine S1800 LCD Screen Replacement
Cosa ti serve
  1. Fujifilm Fine S1800 LCD Screen Replacement, Back Cover Assembly: passo 1, immagine 1 di 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Fine S1800 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Fine S1800 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Fine S1800 LCD Screen Replacement: passo 4, immagine 1 di 2 Fujifilm Fine S1800 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: passo 5, immagine 1 di 2 Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: passo 5, immagine 2 di 2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Fine S1800 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Fine S1800 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
Conclusione
USF Tampa, Team 8-6, Eyestone Spring 2017 Membro di USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 531
