Salta al contenuto principale
Fujifilm Endeavor 100ix Power Button Replacement
Cosa ti serve
  1. Fujifilm Endeavor 100ix Power Button Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Power Button Replacement: passo 2, immagine 1 di 1
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Power Button Replacement: passo 3, immagine 1 di 1
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Fujifilm Endeavor 100ix Power Button Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Fujifilm Endeavor 100ix Power Button Replacement: passo 5, immagine 1 di 1
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Power Button Replacement: passo 6, immagine 1 di 2 Fujifilm Endeavor 100ix Power Button Replacement: passo 6, immagine 2 di 2
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Fujifilm Endeavor 100ix Power Button Replacement: passo 7, immagine 1 di 1
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Fujifilm Endeavor 100ix Power Button Replacement: passo 8, immagine 1 di 1
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Fujifilm Endeavor 100ix Power Button Replacement: passo 9, immagine 1 di 1
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Fujifilm Endeavor 100ix Power Button Replacement: passo 10, immagine 1 di 1
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Fujifilm Endeavor 100ix Power Button Replacement: passo 11, immagine 1 di 2 Fujifilm Endeavor 100ix Power Button Replacement: passo 11, immagine 2 di 2
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
  12. Fujifilm Endeavor 100ix Power Button Replacement, Power Button: passo 12, immagine 1 di 1
    • Look on the inside of the black back casing.
    • Locate the red, rubber power button.
  13. Fujifilm Endeavor 100ix Power Button Replacement: passo 13, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using the tweezers, grab the red, rubber power button and pull it off the casing.
    • Discard the faulty power button.
    • Grab the new power button with the tweezers.
    • Put the power button into place by placing it where the old button was.
Conclusione
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
Eric Nicolai
Membro da: 01/10/11
679 Reputazione
6 Guide realizzate
Cal Poly, Team 13-5, Forte Winter 2011 Membro di Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Membri
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,822
