Salta al contenuto principale
Fujifilm FinePix Z90 Lens cover/case Replacement
Cosa ti serve
  1. Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: passo 1, immagine 1 di 2 Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: passo 1, immagine 2 di 2
    • Use a small #000 Phillips screwdriver to take the screws out. Keep all the screws in a container and the two different types separate.
    • Remove the two screws on the right side.On the same side there is USB connector, open that little door and unscrew the little screw inside of it.
  2. Fujifilm  FinePix Z90 Lens cover/case Replacement: passo 2, immagine 1 di 2 Fujifilm  FinePix Z90 Lens cover/case Replacement: passo 2, immagine 2 di 2
    • Take the two screws on the left side and the two screws on the bottom of the camera.
  3. Fujifilm  FinePix Z90 Lens cover/case Replacement: passo 3, immagine 1 di 2 Fujifilm  FinePix Z90 Lens cover/case Replacement: passo 3, immagine 2 di 2
    • By now you will have the front case and the back case separated from each other.
Conclusione
Sam Clark
Membro da: 11/03/15
301 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 Membro di UMass Dartmouth, Team 1-6, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G6
2 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 271
