Salta al contenuto principale
FujiFilm FinePix S5100 Battery Lead Terminals Replacement
Cosa ti serve
  1. FujiFilm FinePix S5100 Battery Lead Terminals Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your camera is in the off position.
    • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
    • Open the battery door by pushing down and in the direction of the arrow on the door.
  2. FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 3, immagine 1 di 1
    • Remove four AA batteries from the camera.
  3. FujiFilm FinePix S5100 Battery Lead Terminals Replacement, Back Cover: passo 4, immagine 1 di 1
    • Turn the camera so the screen is facing you and the camera lens is facing away from you.
  4. FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 5, immagine 1 di 3 FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 5, immagine 2 di 3 FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 5, immagine 3 di 3
    • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
    • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
    • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
    • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
  5. FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 6, immagine 1 di 3 FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 6, immagine 2 di 3 FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 6, immagine 3 di 3
    • Carefully pull the back cover and separate it from the rest of the camera body.
    • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
  6. FujiFilm FinePix S5100 Battery Lead Terminals Replacement, Battery Compartment: passo 7, immagine 1 di 3 FujiFilm FinePix S5100 Battery Lead Terminals Replacement, Battery Compartment: passo 7, immagine 2 di 3 FujiFilm FinePix S5100 Battery Lead Terminals Replacement, Battery Compartment: passo 7, immagine 3 di 3
    • Remove the single 1.3mm Phillips #000 screw.
    • Carefully remove the battery compartment from the rest of the camera.
  7. FujiFilm FinePix S5100 Battery Lead Terminals Replacement, Battery Lead Terminals: passo 8, immagine 1 di 2 FujiFilm FinePix S5100 Battery Lead Terminals Replacement, Battery Lead Terminals: passo 8, immagine 2 di 2
    • Remove two 0.6mm Phillips #000 screws from the metal battery terminal lead.
  8. FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 9, immagine 1 di 2 FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of tweezers, remove the two back panel pieces from the battery terminal leads found inside of the battery compartment door.
  9. FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 10, immagine 1 di 3 FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 10, immagine 2 di 3 FujiFilm FinePix S5100 Battery Lead Terminals Replacement: passo 10, immagine 3 di 3
    • Using the a pair of tweezers, remove one (+)positive and one (-)negative battery terminal leads from the battery compartment.
Conclusione
Un commento
hello, could you help me with the repair of the power button of a camera fuji finepix HS 20 EXR since the problem lies in the fact that after pressing the trigger and taking a photo, the camera turns off.
Israel Aldana - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 811
