Introduzione
This guide will walk the user through replacing the battery compartment of a FujiFilm FinePix S5100. You will require a Phillips #000 screwdriver. Before beginning, ensure that the camera is in the off position prior to replacement.
Cosa ti serve
Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
Turn the camera so the screen is facing you and the camera lens is facing away from you.
Remove the single 1.3mm Phillips #000 screw.
Carefully remove the battery compartment from the rest of the camera.
