Salta al contenuto principale
FujiFilm FinePix S4500 Viewfinder Replacement
Cosa ti serve
  1. FujiFilm FinePix S4500 Viewfinder Replacement, LCD: passo 1, immagine 1 di 1
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 Viewfinder Replacement: passo 2, immagine 1 di 1
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 Viewfinder Replacement: passo 3, immagine 1 di 1
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 Viewfinder Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 Viewfinder Replacement: passo 5, immagine 1 di 1
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 Viewfinder Replacement: passo 6, immagine 1 di 2 FujiFilm FinePix S4500 Viewfinder Replacement: passo 6, immagine 2 di 2
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 Viewfinder Replacement: passo 7, immagine 1 di 1
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 Viewfinder Replacement: passo 8, immagine 1 di 2 FujiFilm FinePix S4500 Viewfinder Replacement: passo 8, immagine 2 di 2
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
  9. FujiFilm FinePix S4500 Viewfinder Replacement, Viewfinder: passo 9, immagine 1 di 2 FujiFilm FinePix S4500 Viewfinder Replacement, Viewfinder: passo 9, immagine 2 di 2
    • Remove the highlighted 2.7 mm Phillips #1 screws to release the metal cover.
  10. FujiFilm FinePix S4500 Viewfinder Replacement: passo 10, immagine 1 di 1
    • Turn the camera on its side and remove the highlighted 2.7 mm Phillips #1 screws.
  11. FujiFilm FinePix S4500 Viewfinder Replacement: passo 11, immagine 1 di 1
    • Lift and remove viewfinder cover
  12. FujiFilm FinePix S4500 Viewfinder Replacement: passo 12, immagine 1 di 1
    • Use the plastic opening tool to remove the ribbon wire from inside the camera
  13. FujiFilm FinePix S4500 Viewfinder Replacement: passo 13, immagine 1 di 1
    • Remove the viewfinder assembly from the camera
Conclusione
Vicente Rios
Membro da: 01/25/17
708 Reputazione
6 Guide realizzate
Cal Poly, Team 9-4, Banghart Winter 2017 Membro di Cal Poly, Team 9-4, Banghart Winter 2017
CPSU-BANGHART-W17S9G4
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 893
