Salta al contenuto principale
FujiFilm FinePix A340 Motherboard Replacement
Cosa ti serve
  1. FujiFilm FinePix A340 Motherboard Replacement, Outer Case: passo 1, immagine 1 di 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Motherboard Replacement: passo 2, immagine 1 di 3 FujiFilm FinePix A340 Motherboard Replacement: passo 2, immagine 2 di 3 FujiFilm FinePix A340 Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Motherboard Replacement: passo 3, immagine 1 di 2 FujiFilm FinePix A340 Motherboard Replacement: passo 3, immagine 2 di 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Motherboard Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Motherboard Replacement: passo 5, immagine 1 di 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Motherboard Replacement: passo 6, immagine 1 di 1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Motherboard Replacement: passo 7, immagine 1 di 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Motherboard Replacement: passo 8, immagine 1 di 1
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Motherboard Replacement: passo 10, immagine 1 di 2 FujiFilm FinePix A340 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove black sticky tape from circuit board and camera case.
  11. FujiFilm FinePix A340 Motherboard Replacement: passo 11, immagine 1 di 2 FujiFilm FinePix A340 Motherboard Replacement: passo 11, immagine 2 di 2
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing assembly as to not break any solder leads or damage lens assembly.
  12. FujiFilm FinePix A340 Motherboard Replacement: passo 12, immagine 1 di 2 FujiFilm FinePix A340 Motherboard Replacement: passo 12, immagine 2 di 2
    • Remove the logic board by pulling straight away from assembly.
Conclusione
Cody
Membro da: 04/18/10
47 Reputazione
4 Guide realizzate
Cal Poly, Team 7-11, Maness Spring 2010 Membro di Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,827
