Salta al contenuto principale
Fugoo Tough Charging Port Replacement
Cosa ti serve
  1. Fugoo Tough Charging Port Replacement, Charging Port: passo 1, immagine 1 di 3 Fugoo Tough Charging Port Replacement, Charging Port: passo 1, immagine 2 di 3 Fugoo Tough Charging Port Replacement, Charging Port: passo 1, immagine 3 di 3
    • Begin by unscrewing the four 10.72mm corner screws using the h2.0 screw driver.
    • Using the h1.5 screwdriver and remove remaining six 5.79mm screws on the front of the speaker.
    • Pull front part of shell away from back part of shell.
  2. Fugoo Tough Charging Port Replacement: passo 2, immagine 1 di 3 Fugoo Tough Charging Port Replacement: passo 2, immagine 2 di 3 Fugoo Tough Charging Port Replacement: passo 2, immagine 3 di 3
    • Change to the h1.3 head. Remove all 4-5.57mm screws on both speaker covers
    • Pull on the speaker covers, thus removing them
    • Rotate to side the speaker that has the charging port. Remove the 4-5.57mm screws of the facing you.
    • Rotate the speaker 180 degrees and then remove 4-5.57 screws on the side speaker that has the power/bluetooth buttons
  3. Fugoo Tough Charging Port Replacement: passo 3, immagine 1 di 3 Fugoo Tough Charging Port Replacement: passo 3, immagine 2 di 3 Fugoo Tough Charging Port Replacement: passo 3, immagine 3 di 3
    • Have back of speaker facing you, remove 5-12.70mm screws using 1/16 flat head screwdriver.
    • Using the plastic opening tool you will be able to wedge back face of speaker off
  4. Fugoo Tough Charging Port Replacement: passo 4, immagine 1 di 2 Fugoo Tough Charging Port Replacement: passo 4, immagine 2 di 2
    • The circuit board will be revealed, you will notice the various individual speaker connections to the circuit board.
    • Remove blue "clip" from the circuit board.
    • From this point, pull the side panel off gently, exposing the charging port.
    • At this time, you can remove the charging port and replace it.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,588
