Introduzione
Use this guide to check the the condenser of your Frigidaire side-by-side refrigerator. This unit is located behind the rear cover on the back of your refrigerator.
The condenser releases heat from the compressed refrigerant coming from the compressor. This heat ultimately is heat removed from the interior of your fridge.
If the condenser gets dirty then airflow over it can't as easily remove heat. This leads to your refrigerator working harder, using more energy and heating up in the fresh food and freezer compartments.
This guide was created using a Frigidaire model FFSS2614QS6A side-by-side refrigerator. Other side-by-side units should be similar.
Cosa ti serve
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Use a 1/4" nut driver to remove the four screws securing the rear cover to the refrigerator.
Lift the rear cover until it is free of the tabs.
If the water supply hose is not used, pass it through the hole in the cover.
