Salta al contenuto principale
Frigidaire Gallery Water Filter Replacement
Cosa ti serve
  1. Frigidaire Gallery Water Filter Replacement, Water Filter: passo 1, immagine 1 di 1
    • Locate the water filter in the back of the interior compartment.
    • It looks like a long white cylinder.
  2. Frigidaire Gallery Water Filter Replacement: passo 2, immagine 1 di 2 Frigidaire Gallery Water Filter Replacement: passo 2, immagine 2 di 2
    • Push back on the compartment to remove the filter.
    • The filter will then pop out.
    • Remove the used filter and discard it.
  3. Frigidaire Gallery Water Filter Replacement: passo 3, immagine 1 di 3 Frigidaire Gallery Water Filter Replacement: passo 3, immagine 2 di 3 Frigidaire Gallery Water Filter Replacement: passo 3, immagine 3 di 3
    • Unwrap the replacement filter from its packaging.
    • Insert the replacement filter into the water filter housing.
    • You should hear an audible click when the filter is in place.
  4. Frigidaire Gallery Water Filter Replacement: passo 4, immagine 1 di 1
    • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
    • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 82
Ultimi 30 Giorni: 286
Tutti i Tempi: 4,808
