Salta al contenuto principale
Frigidaire FPBS2778UF5 Drawer Handle Replacement
Cosa ti serve
  1. Frigidaire FPBS2778UF5 Drawer Handle Replacement, Drawer Handle: passo 1, immagine 1 di 2 Frigidaire FPBS2778UF5 Drawer Handle Replacement, Drawer Handle: passo 1, immagine 2 di 2
    • This is what the handle looks like when it's loose or is about to fall off.
  2. Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 2, immagine 1 di 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 2, immagine 2 di 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 2, immagine 3 di 3
    • Remove the four screws (two on each side) from beneath the handle using an Allen key.
    • You might need to press the Allen key hard inside for it to unscrew (if loosened).
  3. Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 3, immagine 1 di 2 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 3, immagine 2 di 2
    • Make sure the nuts holding the handle are secure. Only use your hands to tighten them, as using a wrench might damage the fridge.
  4. Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 4, immagine 1 di 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 4, immagine 2 di 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 4, immagine 3 di 3
    • Ensure that the nuts are securely inside the handle. Keep them inside the entire time to make the process easier.
    • Make sure nothing is inside on both sides of the handle which may have been causing it to loosen up.
  5. Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 5, immagine 1 di 2 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 5, immagine 2 di 2
    • Clean the inside with cotton swabs to prevent future problems.
    • This step is optional.
  6. Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 6, immagine 1 di 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 6, immagine 2 di 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 6, immagine 3 di 3
    • Loosen the nuts on both sides until they are not seen inside.
    • This will keep the holder stable on the fridge when it's screwed in.
  7. Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 7, immagine 1 di 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 7, immagine 2 di 3 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 7, immagine 3 di 3
    • Correctly place the holder in the correct holes on both sides.
    • Hold the holder and press it firmly onto the fridge to keep it steady.
    • You may require another person for this step.
    • Start screwing it back in with the same Allen key.
  8. Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 8, immagine 1 di 2 Frigidaire FPBS2778UF5 Drawer Handle Replacement: passo 8, immagine 2 di 2
    • Make sure the screws are tight.
Linea Traguardo
Parth Gupta
Membro da: 01/09/24
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 56
