Salta al contenuto principale
Frigidaire FFPE45B2QM Refrigerator Door Replacement
Cosa ti serve
  1. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Broken Hinge: passo 1, immagine 1 di 1
    • Carefully pop off the cover using a spudger or other opening tool.
  2. Frigidaire FFPE45B2QM Refrigerator Door Replacement: passo 2, immagine 1 di 1
    • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  3. Frigidaire FFPE45B2QM Refrigerator Door Replacement: passo 3, immagine 1 di 2 Frigidaire FFPE45B2QM Refrigerator Door Replacement: passo 3, immagine 2 di 2
    • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
  4. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Refrigerator Door: passo 4, immagine 1 di 1
    • Remove the door by slowly lifting straight up, put the door off to the side.
  5. Frigidaire FFPE45B2QM Refrigerator Door Replacement: passo 5, immagine 1 di 1
    • Get a new, non-damaged door.
Conclusione
Altre 2 persone hanno completato questa guida.
Peterluchini
Membro da: 11/05/15
556 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 Membro di UMass Dartmouth, Team 1-2, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G2
3 Membri
3 Guide realizzate
Un commento
So this is a 4.5 cubic foot mini-refrigerator. I suppose the door was damaged in moving the refrigerator - maybe dropped because it has a weight of 58 pounds.
doctordon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,421
